주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
Flash Storage Firmware Update Won't Install?
I was previously using this device with a 1TB Samsung 970 EVO NVMe SSD & a Sintech Adaptor. I replaced the SSD with it's original shipped Stock Samsung 512 GB SSD with a clean installed Monterey OS & I had this update pop up. No matter what I try it keeps coming back (PRAM / SMC Reset). I have never seen this 'Update' Before.
이미지
이미지
이미지
이미지
이미지
I never tried this method yet just wondering if there is another method possible, the system is running nice and smooth apart from this 'issue'. It seems that I will need to do a clean install again to resolve this. @danj Any Idea on how to 'resolve this'?
UPDATE 06/04/26 I booted externally into Catalina & then Monterey (Internally & Externally). I Clean installed Catalina externally & booted. I used OCLP to install Sequoia but STILL we have the firmware update which does not install. I guess we have to wipe the SSD (Original 512 GB SSD from the unit) which is still installed, and clean install either El Capitan or Monterey to see if that clears the issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Bootup under High Sierra as Monterey might be getting in the way.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
OK I can try that using an external drive that I have a HS installation on! OR did you mean to install HS fresh? HS & Catalina had the firmware updates included in their installers AFAIK, either way I have every OS on an external drive at hand for testing. I will try it when the owner returns in 7 days to collect their hard case. Update then.
의
댓글 달기
답변을 추가하세요
livfe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 15
전체 시간: 134
