주요 콘텐츠로 건너뛰기
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
it won't start. what can I do to start it?
Karcher, powered by honda GCV 160
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 3개
The engine won't start or the pressure pump does not start?
the engine wont start.
On a pressure washer the Water Supply must be ON for the engine to start because the water pump is directly connected to the engine / electric motor. And if there’s no Water pressure, starting the engine / motor will destroy the pump.
There are other factors that can cause an engine not to start which have been answered by others in this thread.
댓글 달기
답변 8개
가장 유용한 답변
PIERRE PAGE, you need 4 things for the engine to work, Spark, Air, Fuel and compression. Make sure that you have spark, check the plugs, your ignition coil, and make sure your ignition air cap is set correctly. Make sure your carburetor float is not stuck, that your gasoline is fresh and that the float valve operates properly. Check your fuel filter, make sure it is not clogged, make sure your fuel lines are properly routed and check the jets in your carburetor, for dirt and maladjustments. Check your valves to make sure they are working correctly, set the valve lash as needed. Let us know what you find with further trouble shooting.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
(1) Read the manual. Check for fuel, oil levels and all the obvious electrical components and connection. Make sure all the taps and switches are set to 'run'.
If no go, then try using an easy start fluid. If it starts, but very soon stops, you may have a fuels supply issue.
If still no go, to check compression, try the starter. If it chuffs, then you have some compression.
To test the spark, take the spark plug out, Put the plug cap on, hold the metal body of the plug to the metal of the cylinder head and try the starter. If a spark appears in the plug's gap, you have a spark.
댓글 달기
Here's the best site I've seen on diagnosing and repair a Karcher Power Washer: http://www.powerwasherplanet.com/power-w...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
해당 답변은 원래 다른 질문에 답변 된 것입니다.
See if the answers here will answer your question:
이 답변이 도움이 되었나요?
점수 1
댓글 달기
A SMALL shot of ether (starting fluid) in the carb will tell you if it's an ignition problem or not. If it fires and dies with the ether, then it's a problem with the fuel system, and not the ignition. If the engine has been sitting unused with fuel in it for and extended period of time, the problem will most likely be in the carb as the crap fuel that we are forced to buy these days with alcohol in it deteriorates quickly and also has a tendency to absorb moisture, which then causes a buildup of deposits in the carb. Once you get it cleaned up and running you need to use a fuel additive if you're going to let it set unused awhile between uses, or run it until it's out of gas. I use Seafoam in all my equipment to keep things clean in the fuel systems.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
That's good advice about the ether.
댓글 달기
My power washer was sitting in my garage for two years and I noticed the gasoline turns bad, I emptied the lines I clean up the carburetor and it still does not work. Are use the brake cleaner as a starter it starts ignite and then dies right after to three seconds that tells it has no ignition problem but the problem with the fuel line or field itself I put a new fuel but still not working. If anybody has the idea what else it can be.
My spark plugs are good I cleaned it it was all new,
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Since it starts and then dies, it sounds like a fuel delivery issue.
This might sound like an odd suggestion, but give it a shot. Remove the gas cap, and then give it a pull. Sometimes, the gas cap on these engines do not vent properly, and it really is as simple as removing the cap. Let me know if that works.
Thanks for suggestion I forgot to mentioned couple days ago I tried again and it worked.
It was the brass bolt still was not clean enough. Side ways was clean but top hole was still clogged.
댓글 달기
The brass bolt (bottom of the carb )? or the brass bowl (under the gas tank) ?
Either case, you have a dirty gas tank. Check for 'red' surface rust covering inside the tank.
Vinegar will help clean. Bathroom shower cleaner works very well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
pull the spark plug after trying to start it. It should either be dry or have gas on it. If its dry, the carb problably needs cleaned by soaking it in carb cleaner, and then blowing out every passage way with compressed air. If it wet with gas, try a new plug and see if it fires while holding it on the head, while pulling the starter rope. If it fires, replace the plug and try to restart it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a DeWalt and it has a low level oil switch built inside. If it is not sitting fairly level it assumes the oil is low and will not start.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
PIERRE PAGE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 55
전체 시간: 30,785
