주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 5월에 출시된 Apple iPod Touch의 7번째 모델입니다. 최대 256GB 저장 용량과 A10 프로세서가 탑재되어 있습니다. 모델 번호 A2178.
Can't remove the front display!
It seems impossible to remove the front display! I used the iOpener repeatedly, a heat gun, all to no avail. I bought a new display and all the tools to replace it, but I can't get started. The adhesive just doesn't want to budge! Help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
OK I got it open now. It took 3-4 days of working t it. Hint to others: The display started to separate slightly on the side, at about 3/4 " above the bottom. I was able to get a razor blade between the display and the frame and slid it down to the bottom, then pulling it across the borttom cutting the adhesive. Now it is on to the rest of the work! DBS
의
댓글 달기
답변 1개
If the front display won't come off, don't force it. Double-check that all screws and ribbon cable connectors have been removed or disconnected. The display may still be held by adhesive clips—apply gentle heat around the edges and use a plastic opening tool to carefully separate it. Forcing it can crack the screen or damage the frame.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Swanson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 187
