주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
Microphone not picking up voice
recently I did a teardown to replace the trackpad, and today I could not get my audio to work on a Zoom call, which sent me down a troubleshooting path. The result is that the computer will produce sound, or register that it is producing sound, if it involves a vibration of the laptop itself, such as a tap, keystrokes, vibration of the table its resting on. I used Quicktime to confirm this. Speakers work fine. The issue is the microphone, likely its connection.
I'm assuming that I did not reconnect one of the cables properly on reassembly, so will be opening it back up, and it would be helpful if I had a sense of which cable to look at when I had it open, as the prior teardown was extensive, delicate, and time-consuming.
I used three different teardown guides as there isn't one specifically for this model (1st Gen M1 13" MBP, late 2020). The main teardown guide I used is this: MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal
Unfortunately not every cable connection is identified.
Is there a map of the internal [microphone] connections available for this (or similar) Macbook Pros?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I think you'll find the Apple Service guide more useful here MacBook Pro (13-inch, M2, 2022) Repair Manual while this is the M2 model the logic is very similar. Follow Troubleshooting microphone issues see if that gets you to the answer!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Russell Hodin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 47
