주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 초에 출시된 2015년형 Retina MacBook 업데이트 버전의 수리 정보 및 안내서. 모델 A1534 / EMC 2991
Everything replaced. Keyboard doesn't work
You know, I've been so dedicated to fix this %#*@ thing. New battery, new logic board, new bottom case with new keyboard (got two because first one was bad). new trackpad, new cables and yet...... the keyboard STILL doesnt work. At this point, with money sunk into this....I guess its just ready to retire. Not sure if anyone has had this experience, but its been pretty frustrating. Everything else works fine otherwise.
Mouse works fine... power button works fine. Just been the keyboard. I've gone through every variable I could think of.. at this point I have no clue what else there.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
It is likely that the very fragile cable from the keyboard / Track pad is either not fully connected or latched down or it has been damaged which is very easy to do on these models. Be careful it did not overheat from something not fully connected or whatever as then it is truly game over as there is no cooling fans on these models and the CPU will overheat & eventually short out. I have one here that suffered the same plight.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 30
전체 시간: 122
