주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Toyota Vitz is a subcompact hatchback originally launched in 1999 as a successor to the Toyota Starlet. It is being internationally sold as the Toyota Yaris or Echo. There are currently 4 generations of the Toyota Vitz.
Oil in spark plugs
My car has oil in the spark plugs resulting into jerking of the engine and the engine light being on along with the abs light too.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@vijayveera44109 let us know what year and what engine size your Vitz is. As for the ABS light that is something you will have to get the OBDII scanned since there are to numerous errors.
As for your oil in the park plugs, there are many different reasons. wE will need to see what you sparkplugs look like. Take a couple of well focused pictures of the spark plug face so we can see what you see. Most commonly, you do want to go ahead and do a compression test as well as a leakdown test on your engine. That way you get a pretty good idea about what is going on. Could be bad valves, bad piston rings, and even a bad PCV valve. Check your sparkplugs against this
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vijay Veeraragavoodoo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 20
전체 시간: 20
