주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to repair a window pane?
How to replace a broken window - outer pane of double pane window?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Typically you can't replace a single pane of a double pane window. If you look at yours you should see a metal frame between the glass panes. This spacer also holds the glass in a sealed sandwich as the gas between the panes is typically Argon or a mixture of gases to limit thermal loss and the glass is also coated with an IR reflective coating to prevent heat transfer from the suns rays.
If you can remove the broken window sash a local shop should be able to order the needed glass and put it in or you can do it as well just getting the glass from the shop.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
@sandraceccato double pane windows can be repaired, but you usually cannot replace just one broken pane. Instead, you replace the entire airtight glass unit known as the Insulated Glass Unit (IGU). Take a look on here for more info about that and why you can't.
How to remove the window sash and the IGU will depend on your window frame and we would need to see more of that to try and figure that out. Best would be to just take the whole window out and take it to a glazier to replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sandra Ceccato 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 24
전체 시간: 24
