Crank but won't start
1985 5.0 v8 seems like engine not getting fuel just replaced both tanks and both pumps about 3 years ago. Recently replaced high pressure fuel pump futher down line right before going up and into the engine. Replaced the fuel relay and deleted the inertia switch. Im at a loss and dont know what to do. I've checked the filter its clean and I dont know what else to do any help would be appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
If you have starter fluid, spray some into the engine intake, and see if it starts or starts briefly. If so, it is probaly a fuel delivery issue. Then, check the fuel pressure at the rail to make sure it is around 35-45 psi. Also, check your spark plugs, ignition control module, and distributor to see if any of them are the problem.
의
Unfortunately there isn't any Schrader valve on the fuel rails so I disconnected at the filter and no gas even making it to the filter. Also changed the distributor cap a few months ago. And has new starting silanoid.
의
댓글 달기
