주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
질문 마감됨
Are there different hardware versions of the iPhone 4S?
I have been receiving conflicting information, both from forum posts and from AppleCare. Apple reps have told me that there are in fact two different versions of the iPhone 4S, while forum posters are swearing that all 4S are the same leaving the factory.
In your tear-downs, have you noticed hardware differences between the Verizon, Sprint, AT&T, or retail unlocked versions?
Thank you for your time
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 6개
선택된 해법
There is a single iPhone 4S.
This is confusing. There is:
1) iPhone 4 GSM - this iPhone does not have Siri.
2) iPhone 4 CDMA (Verizon and Sprint) - this iPhone does not have Siri.
3) iPhone 4S (one iPhone all identical, compatible with GSM and CDMA) - this iPhone has Siri.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes! there are two distinct versions, as the cell networks use different technologies which require differences. This is no different than any other cellphone maker that offer CDMA & GSM phones.
The guts are different and the cases them selves are slightly different (antenna & SIM slot). The IOS GUI, Apps and the controls are the all same (just minor control settings differences).
Make sure you get the correct one for the cell network you'll be accessing.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
A CDMA iPhone (Verizon) does not have a SIM.
It does not have a SIM slot on the side of the phone either.
So there is 1 difference that makes for 2 different hardware
iPhone chassis/cases.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Some of the guts are different like cables and speakers and antennas.
This happens because with no SIM slot there is more room inside
The phone and they arrange things slightly differently.
Many parts are the same - I'm just very careful and confirm
That each part I buy is made for my exact model.
Know our model number when ordering.
댓글 달기
The answers on this post are all wrong.
The original question was about the 4S and the answers given were for the 4.
For the iphone 4 there is no sim for sprint. For the 4S there is. I just tore one down and replaced the screen yesterday. It had a sim.
The hardware SEEMS to be exactly the same. The part of the phone that utilizes CDMA or GSM is a chipset on the motherboard itself. Not in the internal midframe assembly.
Update
Ok I get how he put it now. Brad is correct.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Sorry Kris but Brad is totally correct, you must have read it wrong.
댓글 달기
Actually there are hardware differences between US/global and EU versions. The top antenna is tuned differently, possibly to comply with local RF standards. Otherwise they are pretty much the same. The BOM option list has 9 entries: GU US/ GUC US/ GU EU. Each with 3 sub models of different storage capacity. These are very subtle differences, I didn't notice until recently.
As for the GU and GUC differences, they share the same hardware but with different burnt-in programming. The GUC ones are provisioned with MEIDs to work on CDMA networks while GU ones are just regular GSM/UMTS phones. These are supposedly software controlled but done in the factory with low level direct programming. Not possible to change outside the factory or it is even meant to be permanent
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I know this is an old post but its one of the top google results so I thought I'd chime in. I have replaced dozens of iPhone 4S screens, batteries, back covers, buttons and charging/data ports and was thrown for a loop when I found a new hard frame type today. The standard iPhone 4S replacement screen did required modification to make it fit (by that I mean cutting off screen anchors). Just an FYI in case your newly purchased screen doesn't fit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,215
