주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
Why is there a blue line on the side of my screen?
My screen has a blue line down the left side. Although small, it is very distracting. Every time i tilt the screen, multiple lines appear. I think it is because the screen is loose but have no idea how to fix it. Please help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 4개
선택된 답변
As usual when troubleshooting a display the advice is to connect the computer to an external monitor to check if the problem is limited to the display assy or is caused by a faulty graphic card on the logic board. Identical abnormal video signal on the external monitor would lead to a problematic logic board diagnostic.
Vertical lines are often caused by a LCD panel electronics failure. The LCD electronic board is located at the display upper side. Without moving the lid try to apply pressure each side of the iSight camera and check if there is a change in the displayed video onscreen.
http://img.alibaba.com/photo/229809179/S...
The LVDS (video cable) could also be the culprit since the cable runs thru the MBP hinche and can be damaged inside the hinge or having a loose connection at the connectors ends. Alteration of the video signal onscreen when moving the lid up and down often indicate a faulty LVDS cable.
해당 답변은 도움이 되었습니까?
점수 6
댓글 3개:
iam speechless 100 100
wow i would have never thought of doing this if not mentioned here. and it totally solved the issue. thanks so much.
댓글 달기
I'm sure my LVDS is the problem, likely at the hinge cuz I can tweak the lid and make the lines change or go away for a minute. So, any shortcuts or a way to take the pressure off the cable at the hinge?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i think have the same problem with LVDS. When I press the lower left corner of the screen (small pressure is sufficient) a lot of vertical lines appears.
May I have to change the entire LCD panel or only LVDS?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
how getting a line from my tv
댓글 달기
On My MacBook Pro 13’ I do have a faint blue line on my screen. You Could try Pressing Underneath The Screen, On the Black Part. It did work for me But every time you restart or run out of charge it comes back. If you try this method get ready to Press Underneath The Screen A lot. This Morning I saw there was the line on my screen and i tried doing my method And this Time it didn’t Work. This is a temporary fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Teak Sangaphunchai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 56
전체 시간: 51,800
