주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
주택, 사무실 및 자동차에 사용되는 에어컨 유닛의 수리 및 문제해결 가이드입니다.
Won't turn on
I have an older Danby, which I keep unplugged when not in use. When I plug it in, it beeps and the display shows for a second, then disappears. The power button doesn't turn it on. Unplugging and replugging gives the same result, a beep and a quick display of the last temp I had it set on, then it goes off again. Power button won't turn it back on. I've already tried the test and reset buttons on the power cord, which appear to be functioning properly.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
@trinklingcreek what is the exact model number for your AC?
의
DPA120E1BDB. I've already checked the owner's manual. There is nothing about maintenance or troubleshooting.
의
댓글 달기
답변 1개
Hello, it looks like the motherboard is shutting down for some reason, since you're unplugging it each time you want to turn it off, maybe you're preventing the AC from starting a proper shutdown sequence, perhaps the fan has to keep turning for around 30s to prevent moisture or condensation to form on the motherboard or some electronic part.
I think a good start is to reach the board and clean it if possible or jiggle it, just don't forget to unplug the cord and becarful of the capacitors they still can hold charge.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Trinkling Creek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 10
전체 시간: 69
