주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola DROID 3는 Google의 Android 2.3 운영 체제를 사용하는 Verizon Wireless의 스마트폰입니다.
Droid 3 Keyboard replacement
I have a Droid 3 that has a keyboard that is starting to get unresponsive keys when pressed with an average amount of pressure. It requires a good mashing for the space bar, Z, M, @ keys.
This question was posted before, but no reply. ( it has been posted twice )
I couldnt find manual somewere, people refered me to this website, i hope i can get the help i need here.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Hi. Unfortunately it seems we do not have any repair guides for the Motorola Droid 3 at the moment. But we do have a Motorola Droid 3 Teardown. Be advised though, Teardowns provide a look inside a device and should not be used as disassembly instructions. If your goal is to replace the keyboard, you may follow the teardown at your own risk. Good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
well yeah, thanks for your answer first. I have seen the teardown, but i am not sure. If it is not neccessairy, to completely pull everything out, i will be busy for a long time, for nothing, with a chance to brick it ( i am not so experienced with it )
With previous model, it does not need to
http://www.youtube.com/watch?v=NAgGtK4K4...
의 공유
댓글 달기
I would like some help with this too. Certain keys are becoming unresponsive.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
what have you tried, which keys are not responding? Give us more details and remember that you posted your question as an answer to an old question. Once we have more information, this may be converted to its own question. That way more people will see it and you may get the answer you will need to fix your phone. :-)
의 공유
댓글 달기
답변을 추가하세요
Ozi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 2,207
