주요 콘텐츠로 건너뛰기
Pentium M 735 1.7 GHz, 512 MB RAM, 60 GB HDD
3 질문 전체 보기
laptop wont charge or power on. power polarity issue?
laptop not used for 6 mo to a year. cant find power adapter ordered new one. used universal adapter plugged into car lighter socket did not notice any charging lights come on or any sounds smells etc but realized that I may have reversed the polarity on the charger tip.
so until I receive power adapter have no way to charge battery or run computer without battery because the universal power is not charging or powering laptop. so not sure new power adapter will work either.
is it possible that by reversing the polarity and pushing the power on button that I damaged the power system and if so what is the most likely damage and is it repairable by me? and regardless of the battery possibly being unchargeable shouldn't lights indicating charging or connected to power be coming on.
I have read elsewhere about similar problems of not powering on and resetting the laptop but those questions and answers did not include someone reversing the polarity on the power adapter.
thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
tedd brown, I would first check your "universal power adapter" Your Sony requires DC input of 16V - 3.75A and a max of 60 watt. Most universal adapters do not supply this. That may be the reason for it not coming on or charging. The tip is positive and the barrel is negative.
이 답변이 도움이 되었나요?
점수 1
댓글 8개:
thanks for the response to my question. the adapter does indeed have a setting for 16v and I set at least that part right based on the label on the laptop.
I know from reading that it could be a number of things but was exploring here whether I could fix it if I did damage it with the reversed polarity.
the ifixit website has a great series of photos for taking apart my particular laptop and I could replace parts if needed.
I was trying to see what parts might have the highest probability of being damaged and whether they are replaceable if that is what it comes to. I have a newer laptop so beyond being fun this might restore the thing so I can give it to somebody who can use it.
thanks
first time user so posted my response as an answer rather that a comment.
thanks
Right now I would not worry to much about replacing anything. Wait and see what you get when you use the proper adapter. 3.75A is quite a bit of current and I would not expect your laptop to show any signs of life with anything below 2A. If it did (again I do doubt it at this time) indeed suffered any kind of damage, check the caps and other components near the DC port. You should easily identify any charred components.
I had the same question about polarity.. then read this and it said yes. The tip is positive and the barrel negative.. so by the tip, do you mean inside it or on the outside? And by barrel the outside? Or opposite?
My Vaio pcg-81114l will light up like it’s charging sometimes.. try to turn it on and the power button will light up if u hold it but off if u let it go. Occasionally it’ll stay lit up but no signs of fan, hard drive kicking in, or no screen.. it’ll stay on like that for a long time.. not shut down.. I don’t hear the beep saying it passed POST test.. but most I’ve had doesn’t beep nowadays.. it’s getting volts to the motherboard,, I have a variable power supply.. it’ll kick on after about 16V.. show charging light.. kinda confused
Also.. I have the connector unhooked and connected the wires to an adapter that fits my universal power supply and has the basic slots with screws to tighten on each wire.. red or black.. plus a blue wire.. google claimed it to be a a low power mode or something.. said to leave it unhooked while troubleshooting..
댓글 3개 더보기
댓글 달기
답변을 추가하세요
tedd brown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 28
전체 시간: 3,214
