주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 3DS의 향상된 버전입니다. 더 큰 화면, 더 긴 배터리 사용 시간, 더 높은 픽셀 밀도, 그리고 개선된 디자인을 특징으로 합니다.
3d effect won't turn off
i opened the top case to clean the top screen and once i put the components back in, the 3d slider wont stay off.
the console starts in the minimum 3d effect, even if the tab is at the very bottom of the physical slider. if you turn the slider to max then back to off, the effect will turn off for a few seconds but then coming back to minimum 3d.
unsure as to what could be causing this, does anyone have an idea how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi!
You need to open it up again and make sure that the slider is inserted correctly. Make sure that nothing is blocked and that the black tab is indeed correctly inserted in the slider.
If possible, please share some pictures with us.
If this is the case, you might need to replace it completely to get it fixed again.
This is most likely a hardware fault.
Thanks!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ezra Barrett (EZRA) 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 31
전체 시간: 75
