주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mercury Marine 및 관련 국제 선외기 라인과 연관된 구형 Mariner 선외기 모터에 대한 수리 정보 및 서비스 지원입니다.
2 stroke won't start
Why won't my 2 stroke marine motor not start?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Adding to moe_r's reply, a spark test would be removing one or all spark plugs, examining them for fresh raw fuel (wet, smell), then connecting to ignition coil or wire while grounding the plug base to the engine (unpainted parts). Do you see/smell fuel on plugs or not? Try starting and observe for spark on the plug. Is your outboard electronic fuel injection or carburetor? EFI systems can be difficult to diagnose but not insurmountable with background info. EFI can have electronically controlled spark and fuel injectors. Carburetors fall into two types; float or diaphragm operated from crankcase pressure.
의
댓글 달기
답변 1개
Main reasons an outboard motor won't start: 1. No fuel; 2. No spark 3. No compression Possibly, if you provide more details, I could be more specific. e.g. How old is the gas? Have you changed the spark plugs recently? Pull start or electric start? How many cylinders? How old is the motor? Whar is the motor's serial number? (usually on a plate or decal on the clamp beneath the powerhead). If you've ever forgotten to put the two-stroke oil in the gas (or, fill the oil reservoir), that can be fatal (check the compression). Does it want to start? Or is there no sign of firing when you try to turn it over?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Robin Kline 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 37
전체 시간: 64
