주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Mineral Oil Between Glass and LCD
I've got what I'm pretty sure is a new one. My iPhone 4S (AT&T) was having problems muting the microphone as it believed a headset was plugged in. My solution was to deliver a short spray of WD-40 into the headphone jack, which solved the problem but caused a new one. Now there is a small blob of oil visible on top of the LCD. I'd like to know if it might be possible to clean it out by taking apart the phone, or if I would be better off replacing the whole front LCD/digitizer combo.
You can sort of see the blob in this photo, right in the middle of the screen. There is a very faint discoloration and darkening around it, leading up to the headphone jack where it started, but the blob in the middle is the worst. If I press hard I can get it to disperse but it quickly re-forms.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Hey there. This is really interesting. It is generally assumed that the LCD is fused to the front panel, but somehow, you managed to get schmutz inbetween the two panels. Either way, the two panels have to be replaced together, which is quite a bummer. iFixit has the guide and the part.
That is quite a misfortune that you have going there. Before replacing anything, try opening up the device and cleaning up any of the remaining WD-40.
iPhone 4S Screen 이미지
상품
iPhone 4S Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Can't tell from the picture can you place something against the edge to wick up the WD40 out of the gap and then use a hair drier to heat (carefully!) the glass area to evaporate the remaining oil. This still might leave a stain. Otherwise its replace the parts time!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I don't know whether I can wick anything up, since the oil is primarily concentrated in that blob, and the trail leading to is it extremely thin... that trail could even just be dirt left behind. Haven't tried heating, but it has been in my pocket and in the sun for about a week.
댓글 달기
having the same issue.. used WD 40 to clean the sim slot and it deteriorated my lcd, it has been like this for some weeks, but recently i've been looking on the web and decided to try some methods, I will try the hair drier later on tonight and in the weekend ( if the problem is not fixed ) i will dunk it in a container of uncooked rice.
Wish me luck!
P.S.: I'll be back with the results
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Sorry to tell you Rice won't help you here ;-{ Its' time to get a new panel if the air dryer doesn't do it.
댓글 달기
tried the hair drier.. no major effects.. I'm affraid to try another display because this one has much more live colors then the rest..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bennettprescott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 10
전체 시간: 10,603
