truck won't start
2004 ford f-150 Lariot Triton 5.3 motor, 4r70w /475re transmission Truck just stopped starting, first it would start and could not put in drive, then just stopped starting, battery is charged, I have nothing, no lights, no horn nothing electrical, But when I turn the key off there is a clicking noise coming from the back of cab and truck bed, So I'm guessing electrical since it all happened at once.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
@spot84536 We have no clue what truck you have. In these scenarios, we absolutely need precise details, not just "truck won't start". We can't help you if you don't give us more information.
의 공유
@spot84536 what my colleague is saying is that we really need to know the exact make, model year, engine size and what type of transmission it has. Otherwise we are left in the dark and can't provide any meaningful answer. :-)
The clicking noise you are hearing could be a relay chatter from the fuel pump relay or EVAP system.
의 공유
Thanks guys , I can't believe I forgot the most important info, I edited the post.
의 공유
Are battery connections corroded, loose? Water and baking soda with a tooth brush will easily dissolve and neutralize dried battery acid venting from batteries, drying out and leaving bluish white deposits. Water rinse. Examine main ground cables too, battery to chassis, chassis to engine block. If not sure of battery age, try a boost from another battery to eliminate a suspect battery. If your F150 starts up, measure battery/alternator voltage; battery standby voltage - 12.5vdc, engine running voltage - 14.5vdc. Be sure the drive belt is tight, not loose. Free battery/alternator tests at most auto stores like Autozone.
의 공유
댓글 달기
