주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
Trackpad replacement MBP 17" 3.06GHZ core 2 duo
My track pad is not working very well sometimes it will if I hit it really hard it will work but the touch feature works but not the click so no click and drag etc.
My understanding is that to replace it is the whole case is there a chance its just the screws loose?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
I don't think a loose screw is the problem, however you can replace just the track pad.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
There is a chance it is just the adjustment screw for the trackpad. Actually it sounds like it is EXACTLY the adjustment screw for the trackpad.
Do a search online for this repair. you need a special screw driver, but it totally fixable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Here's the IFIXIT guide info: MacBook Pro 15" Unibody Early 2011 Trackpad Replacement go to Step 30 to adjust the click plate.
My trackpad is from a 2009 17" MBP. If I need a replacement Is the replacement the same as an early 2011? Mine is very hard to press and it only works in the lower right hand corner and I have to press very hard to get it to work.
@Ellen - You really should post your own question here as your system & problem is different. I suspect your battery has swelled causing pressure from the inside against the trackpad. I would start there.
댓글 달기
귀하의 답변을 추가하세요
jchase 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,696
