주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
iPhone 4 will not hold charge while plugged in a computer?
Hello,
Recently my iPhone 4 stopped holding it's charge while plugged into my computers. I have tried different USB ports on my work computer and my laptop at home and encounter the same problem. I used the same cable for all occasions. It will however hold charge once its plugged into the power adapter.
I have made a few repairs to the iPhone but I don't believe i've moved the Dock Connector, so it may be a problem with the Battery? I also lost my Pressure Contact (The clasp that goes over the battery connector) and had the iPhone running for a few weeks... not too sure if that will cause any damage? I found it a couple days ago and put it back in... no change.
I am considering replacing both the Dock Connector and Battery but I would like to try and solve the mystery first :)
Any thoughts/recommendations?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Dradeel, sounds like the battery to me. The AC adapter supplies about 1 amp to the phone when charging, compared to the USB port's 500mA. I'd start with the battery and make sure your contacts are clean and appropriately seated. If that does not help, then you can look at the dock connector as well as charging circuit. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dradeel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 625
