주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
코드네임 A34인 6세대 Maxima는 미국, 캐나다, 멕시코에서만 판매되었습니다. 2003년 북미 국제 오토쇼에서 2004년형 모델로 처음 공개되었습니다.
Driver's door key lock
The key will not manually unlock the driver's door. The mechanism appears to be frozen. How do I access the mechanism to try and free it up?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
If frozen from subfreezing temps, you may be able to defrost the lock cylinder with lock lube or hand sanitizer. Warming the key blade can help melt frozen water while lock lube/sanitizer will help lube and free the lock cylinder.
If not frozen from subfreezing temps and seized from years of non use, you may have to remove the lock cylinder from inside the door panel. You may have to decide whether to attempt removal, cleaning and lubing the lock mechanism and see if lube frees up corrosion for flushing with solvent like throttle cleaner followed by applying lock lube for long term reliability.
의 공유
댓글 달기
답변 1개
I asked FixBot (Ai) for door lock removal with its reply in italics. Beware of Ai mistakes.
For a frozen lock, water freezing can melt with a warmed key along with lock lube or hand sanitizer. If seized and not frozen from freezing temps, removing the lock may be necessary for cleaning, lubing or replacement.
Door Lock Cylinder Service And Repair — 2006 Nissan Datsun Maxima V6 3.5L (VQ35DE) Service Manual ~ LEMON Manuals
"removing door lock cylinder"
To remove the driver's door lock cylinder on your 2004–2008 Nissan Maxima, you will need to access the inside of the door panel and release it from the exterior handle assembly.
Here is what the procedure involves:
  1. Remove the interior door panel: Disconnect the battery 1, pop off the screw cover behind the inside door handle, remove its retaining screw 1, remove the window switch trim and switches 1, and unclip the door finisher panel from its fasteners.
  2. Access the door jamb bolt: Peel back the protective water shield inside the door, locate the rubber grommet on the side edge (jamb) of the door, and remove it. Loosen the Torx retaining bolt hidden inside that hole (this secures the outside handle/lock assembly from the side) 2.
  3. Disconnect the linkage: Detach the key cylinder rod or cable clip linking the cylinder to the internal door latch mechanism 2.
  4. Remove the lock cylinder: From the outside of the door, pull the exterior handle outward, then pull the key cylinder assembly outward and toward the rear of the vehicle to slide it free from its housing or escutcheon (you may need to pop off a small retaining clip or pawl holding it in place) 2.
Let me know if you need help with a specific part of the trim removal or reassembly!
Sources:
1 Genuine Nissan Maxima Door Lock Cylinder
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Romaxco 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 13
지난 7일: 35
지난 30일: 35
전체 시간: 35
