주요 콘텐츠로 건너뛰기
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 질문 전체 보기
Can I fix screen with "random touchs"?
I don't know why, my ipod nano "thinks someone is touching it".
And it access menu, and do things alone!
I just tried to reset, to restore, and even entered diagnostic mode (it says screen are ok).
Many times screen look like unresponsive, because of there is a ghost touching it, I think.
And it's getting worse.
My doubt is: replacing screen will fix it?
Thank you very much.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Edigar, this could be cause by a bad digitizer circuitry. I would change the digitizer and make sure that the connector is clean, no debris or corrosion between the connector and the cable. Here is the guide and the part is available on here as well as many other places. Hope this helps, good luck.
iPod nano (6th Gen) Display Assembly 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Edigar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 645
