주요 콘텐츠로 건너뛰기
whats the best processor replacement I can use
i am looking for the best processor replacement for my Dell Optiplex GX280, can someone please tell me what is the best processor i can use to replace my pentium 4. i need new processor because i mainly will be using my pc for gaming and i want the best that my pc can handle and that will fit in my frameware. someone please help, thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
peter, checked on the Dell forum and this is a list compiled of the CPU's that should be working for your computer:
D7459 Prescott P4 Kit, 520, 2.8Ghz, 800FSB, 1MB
DD517 Prescott P4 64bit Kit, 521, 2.8Ghz, 800FSB, 1MB
D7460 Prescott P4 Kit, 530, 3.0Ghz, 800FSB, 1MB
DD519 Prescott P4 64bit Kit, 541, 3.2Ghz, 800FSB, 1MB
D7462 Prescott P4 Kit, 540, 3.2Ghz, 800FSB, 1MB
D7463 Prescott P4 Kit, 550, 3.4Ghz, 800FSB, 1MB
M8964 Prescott P4 Kit, 550, 3.4Ghz, 800FSB, 1MB
D7464 Prescott P4 Kit, 560, 3.6Ghz, 800FSB, 1MB
M8965 Prescott P4 Kit, 570, 3.8Ghz, 800FSB, 1MB
Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
thank you for your answer. but i got a pentium 4 3.8Ghz and i put it in my PC but when i started it up it said invalid processor. can you help me out again please and explain to me whats going on and what to do to fix it? the processor i have and had from the beginning is a Pentium P4 2.80Ghz/IM/800/04A SL7PR china 5526A54. And the new one i got is a
INTEL Prescott Pentium 4 P4 670 3.8 Ghz SL8PY 2M Cache 800 Mhz FSB Hyper Thread. Please please please! help me out. thank you.
peter, it appears that it will not work, since your chipset does not support the processor.
How we now who is the compatible proccer...???
@unik did you check the list in the answer? Those are the ones.....
댓글 달기
upgarde dual core prosoccer
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Dell optiplex gx280 doesn't support dual-core.
@gigabit87898 do not simply downvote this. You need to clarify whatthe poster tried to say. This could have been a question as well. Do not use downvotes trying to prove a point or because you believe to know better. Only blatantly wrong or willfully disruptive answers should be downvoted. Always consider what would happen if the show is on the other foot.....
댓글 달기
답변을 추가하세요
peter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 4,978
