Battery
답변 1개 0 점 |
No speaker sounds after screen replacement |
답변 1개 1 점 |
usb debugging and locked out |
답변 1개 0 점 |
The battery won't take a charge more than about 5% then stops charging |
문서
모델
XT2141-1
Background
The Motorola Edge 5G UW is a Verizon exclusive phone that is very similar to the Motorola Edge (2022). It's defining feature is the Ultra Wideband (UW) performance. It has four cameras.
If you want to diagnose whether your problem is software or hardware related—including backing up and restoring your device—download the Rescue and Smart Assistant app.
Identification
The Motorola Edge 5G UW has a sleek design with rounded edges. It comes in a Nebula Blue color.
Specifications
Dimensions:
- Width: 2.97 inches (7.54 cm)
- Depth: 0.35 inches (0.89 cm)
- Height: 6.65 inches (16.89 cm)
Weight: 7.11 ounces (28.35 grams)
Operating System: Android 11
Processor: Qualcomm Snapdragon
RAM: 6 GB
Storage: 128/256 GB
Battery: 5000 mAh
Display:
- 6.8-inch FHD+
- 144Hz refresh rate
- 20.5:9 aspect ratiods
Front Camera: 32 MP hi-res
Rear Cameras:
- 108 MP ultra high-res
- 8 MP ultra-wide angle
- 2 MP depth camera
Wireless Connectivity:
- 5G ultra wideband; n260/261
- 5G; n2/5/48/66
- 4G; B2/4/5/13/12/66
- Wi-Fi; 802.11a/b/g/n/ac; 2.4GHz+ 5GHz;
- Wi-Fi hotspot
