주요 콘텐츠로 건너뛰기
iPhone 4S Rear Camera Replacement
필요한 것
  1. iPhone 4S Rear Camera Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
    • Be sure the driver is well-seated when removing Pentalobe screws—they are easy to strip.
  2. iPhone 4S Rear Camera Replacement: 2 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement: 2 단계, 이미지 2/2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4S Rear Camera Replacement: 3 단계, 이미지 1/1
    • Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
    • Remove the rear panel from the iPhone.
  4. iPhone 4S Rear Camera Replacement, Battery: 4 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the following screws securing the battery connector to the logic board:
    • One 1.7 mm Phillips screw
    • One 1.5 mm Phillips screw
  5. iPhone 4S Rear Camera Replacement: 5 단계, 이미지 1/3 iPhone 4S Rear Camera Replacement: 5 단계, 이미지 2/3 iPhone 4S Rear Camera Replacement: 5 단계, 이미지 3/3
    • Carefully push the pressure contact away from the battery connector until it slides free from its position.
    • Remove the pressure contact.
  6. iPhone 4S Rear Camera Replacement: 6 단계, 이미지 1/3 iPhone 4S Rear Camera Replacement: 6 단계, 이미지 2/3 iPhone 4S Rear Camera Replacement: 6 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
    • Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
    • The battery connector comes off vertically from the logic board. Do not apply force sideways.
    • Be careful not to pry at the battery connector socket itself, or it may detach from the logic board. There are four very small solder points awaiting this mistake!
  7. iPhone 4S Rear Camera Replacement, Reassembly tip: 7 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement, Reassembly tip: 7 단계, 이미지 2/2
    • During reassembly, be sure to carefully position the pressure contact back in place. It should rest on top of the Philips screw post shown, and the gold contact should point towards the battery connector.
    • Be sure to clean the pressure contact with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
  8. iPhone 4S Rear Camera Replacement: 8 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement: 8 단계, 이미지 2/2
    • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
    • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
    • If the adhesive is too strong, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use the flat end of a plastic opening tool to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
  9. iPhone 4S Rear Camera Replacement: 9 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement: 9 단계, 이미지 2/2
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • Be careful not to pull the plastic pull tab too hard as it can be ripped off very easily.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the ribbon cable.
    • If your replacement battery came with an uncreased cable, carefully crease the cable into the proper shape before installing the battery into the phone.
    • While installing the replacement battery, temporarily connect the battery connector to the phone to ensure proper alignment. Once the battery is glued in place, disconnect the battery connector.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  10. iPhone 4S Rear Camera Replacement, Rear Camera: 10 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Be wary of the outer plastic ring located on top of the rear camera's flash assembly. It can be easily displaced if not removed during disassembly.
    • You can use tweezers, a plastic opening tool, or a spudger to remove the outer plastic ring.
  11. iPhone 4S Rear Camera Replacement: 11 단계, 이미지 1/1
    • Remove the following four screws securing the cable cover to the logic board:
    • One 2.7 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 1.3 mm Phillips screw
    • One 1.2 mm Phillips screw
  12. iPhone 4S Rear Camera Replacement: 12 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement: 12 단계, 이미지 2/2
    • Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
    • Lift the cable cover from its edge nearest the top and remove it from the iPhone.
  13. iPhone 4S Rear Camera Replacement: 13 단계, 이미지 1/2 iPhone 4S Rear Camera Replacement: 13 단계, 이미지 2/2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • There is a small rubber gasket that sits underneath the rear-facing camera. Make sure that it is properly seated before reassembly.
결론
다른 148명이 해당 안내서를 완성하였습니다.
Walter Galan
696,442 평판
안내서 1,203개 작성하였습니다
댓글 5개
Hello I switched the camera on my 4s , cool it appears the image, but when I do sudden movement she hangs for a few seconds and then back to normal, and I can not record video , and the camera ta unfocused , which can be ? software or hardware?
pedromarques3l - 답글
I got same problem. But sometimes, it is normal. I guess its just the strip problem.
batistanandhu -
Hi - I've changed screen on a lot of iphone 4S.
But I have a problem with 2 of them. When turning them on again the camera just shows a black screen and the flash does not work.
Anyone know what the problem could be ?
Thanks in advance
renereuss1234 - 답글
i want to replace rare camera of iphone 4 with iphone 4s
Shahzaib Kiyani - 답글
Not worth it! You will break the connector and ruin the mood!
Aleksei Marinichev -
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 15
30일 전: 67
전체 시간: 87,025
