주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Force Restart an iPhone 4S
  1. How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 1 단계, 이미지 2개 중 1개 How to Force Restart an iPhone 4S, How to Force Restart an iPhone 4S: 1 단계, 이미지 2개 중 2개
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
    댓글 쓰기
  2. How to Force Restart an iPhone 4S: 2 단계, 이미지 2개 중 1개 How to Force Restart an iPhone 4S: 2 단계, 이미지 2개 중 2개
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 240명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Evan Noronha
회원 가입일: 02/05/15
229,499 평판
안내서 168개를 작성함
24가이드 댓글
what if our power butoon is broken/
Autumn Harris - 답글 공유
Under settings, accessability, turn on assistive touch. You'll have a grey dot floating around on your screen. When you touch the dot, it brings up the full "menu." Touch "device" then a lock button option will show. Press and hold the lock icon. You'll then have the "slide to power off" option. Turn off. Give it a couple minutes. Don't panic, even without the working power button to turn it back on, it's still doable! Just plug the phone in and it'll power right on.
Heather Powers - 답글 공유
thumbs up!!!
itsjustgrace87 - 답글 공유
It worked, I can't believe this! Thank you so much, I tried everything I could think of to get it started. I put it in a bag of rice for 12 hours, a bed warmer, blow dryer, and nothing. I started looking for repair shop's, and stumble on your site, which included all iphones. I went to my phone model and the instructions said force start, and I tried it and presto, I'm back in business. THANK YOU! 724-309-3210
Dr Ed Day - 답글 공유
Great Instructions! Thank you.
georgiaruocco - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 54
지난 30일: 245
전체 시간: 90,910
