소개
多くの最新電子製品は、バッテリーが直接ロジックボードにはんだ付けされています。これにより、バッテリーがコネクタでロジックボードに接続されている他の旧モデルよりも 、バッテリー交換が大幅に難しくなります。このガイドでは、さまざまな難易度のはんだ付けを説明し、電子ガジェットでよく見られる3種類のはんだ付け技法を紹介します。
Step 1: Beginning — 円筒型コンデンサなどの大型スルーホール部品;
Step 7: Intermediate — バッテリーのリード線や抵抗器などの小型スルーホール部品;
Step 11: 上級レベル — 小型表面実装部品。
はんだ付けを行う際には換気を忘れずに! 繊細な電子部品をはんだ付けする時は、ESD(静電放電)安全対策を施した作業環境で、ESD(静電放電)安全のツールを使いましょう。
필요한 것
接合部のはんだを除去するには、はんだ吸い取り線を既存のはんだボールの上に当て、はんだごてで押し付けます。
はんだが溶けて吸い取り線に染み込んだら、吸い取り線を接合部から離します。
残りのリードにも同じ手順を繰り返します。
デバイスを組み立てる際は、これらの手順を逆に実行してください。
다른 433명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 36개
TIP: Another method which works well for clearing solder from holes (especially on repairs like AC Jacks on laptops) is to use compressed air to clear melted solder from holes. A quick blast with a duster can works well (I have even used a drink straw in a pinch and blown out with a blast of air from mouth). Heat the solder until it liquefies, put the duster straw right above the solder and quickly hit the melted solder with an air blast to instantly clear the hole of solder. This works well on very small holes as melted solder does not always push out cleanly with metal tools. You have to be quick with the air blast because the solder re-hardens rapidly.
just be careful doing this lol, flying molten solder can and will burn you or other components.
Logixal -
Flying solder might also get into places you don't want it. Making shorts and other unwanted connections of which you don't know where they are, so it can give you a very hard time finding them.
This is not IPC standards but for the ghetto approach, it will get the job done. I solder in manufacture settings, run my own shop. This is wrong to a degree but will do. If ifixit would like tips from ILLFIXIT then your more then welcome!
Tony Stark - 답글
