주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
12-String Takamine G Series Guitar String Replacement
필요한 것
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 3개 중 1개 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 3개 중 2개 12-String Takamine G Series Guitar String Replacement, Guitar String: 1 단계, 이미지 3개 중 3개
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
    댓글 쓰기
  2. 12-String Takamine G Series Guitar String Replacement: 2 단계, 이미지 2개 중 1개 12-String Takamine G Series Guitar String Replacement: 2 단계, 이미지 2개 중 2개
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
    댓글 쓰기
  3. 12-String Takamine G Series Guitar String Replacement: 3 단계, 이미지 2개 중 1개 12-String Takamine G Series Guitar String Replacement: 3 단계, 이미지 2개 중 2개
    • Place the new string into the hole in the bridge where the pin was taken out.
    댓글 쓰기
  4. 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 3개 중 1개 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 3개 중 2개 12-String Takamine G Series Guitar String Replacement: 4 단계, 이미지 3개 중 3개
    • Place the pin back into the hole to secure the string.
    댓글 쓰기
  5. 12-String Takamine G Series Guitar String Replacement: 5 단계, 이미지 1개 중 1개
    • Grab the string and put it through the hole located on the tuning post of the guitar.
    댓글 쓰기
  6. 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 3개 중 1개 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 3개 중 2개 12-String Takamine G Series Guitar String Replacement: 6 단계, 이미지 3개 중 3개
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
    댓글 쓰기
  7. 12-String Takamine G Series Guitar String Replacement: 7 단계, 이미지 2개 중 1개 12-String Takamine G Series Guitar String Replacement: 7 단계, 이미지 2개 중 2개
    • Turn the tuning peg counterclockwise to tighten the string.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Rey Navarro
회원 가입일: 09/27/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 52
전체 시간: 855
