주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
32" Hisense LED TV Screen Replacement
필요한 것
  1. 32" Hisense LED TV Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 32" Hisense LED TV Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • DO NOT plug the TV into power at any time during this process.
    • To begin, lay the TV screen-down on a smooth surface.
    • Unscrew the screws connecting both support legs to the TV.
    댓글 쓰기
  2. 32" Hisense LED TV Screen Replacement: 2 단계, 이미지 2개 중 1개 32" Hisense LED TV Screen Replacement: 2 단계, 이미지 2개 중 2개
    • To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver.
    • If the screws are difficult to find, remove any screws on the back plate that have an arrow pointing to them like in the second picture.
    • Once all of the screws are removed, carefully pop off the back plate without damaging any of the connected wires.
    댓글 쓰기
  3. 32" Hisense LED TV Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the power cord free from its metal framework.
    • After the power cord has been moved, remove the four screws keeping the housing in place. Once finished, remove the housing as well.
    댓글 쓰기
  4. 32" Hisense LED TV Screen Replacement: 4 단계, 이미지 2개 중 1개 32" Hisense LED TV Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver.
    • Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
    댓글 쓰기
  5. 32" Hisense LED TV Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
    댓글 쓰기
  6. 32" Hisense LED TV Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
    댓글 쓰기
  7. 32" Hisense LED TV Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Completely separate the back from the front and flip the back section over so that the screen is now on top.
    댓글 쓰기
  8. 32" Hisense LED TV Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
    • DO NOT detach both ends of the plastic. Only detach the end that is easily removed from its adhesive.
    댓글 쓰기
  9. 32" Hisense LED TV Screen Replacement: 9 단계, 이미지 1개 중 1개
    • After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
    • Next, the circuitry needs to be removed from the TV itself. Lift the screen circuitry free from the adhesive and then lift the screen free from the back section of the TV.
    댓글 쓰기
  10. 32" Hisense LED TV Screen Replacement: 10 단계, 이미지 2개 중 1개 32" Hisense LED TV Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Connor French
회원 가입일: 09/29/15
1,475 평판
안내서 2개를 작성함
28가이드 댓글
Where can I buy the replacement panel?
Arinah Arin - 답글 공유
Could you please post the panel code of this tv model (32H3C)? I guess it could be the same my hisense tv need . It could help me to find the right spare part.
Thx
Alexis - 답글 공유
where can i buy Hisene LCD TV Screen pls?
H Te Tea - 답글 공유
where do I buy a replacement screen for 32inch hisence smart tv
Shaik Ahmed Khaleck - 답글 공유
How can I buy the 55inch screen. The straight TV not curve
Solomon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 73
지난 30일: 438
전체 시간: 59,752
