주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
8BitDo Ultimate Wireless Button Conductive Pad Replacement
필요한 것
  1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: 1 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    댓글 쓰기
  2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 2 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    댓글 쓰기
  3. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 3 단계, 이미지 3개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 3 단계, 이미지 3개 중 2개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    댓글 쓰기
  4. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 4 단계, 이미지 3개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 4 단계, 이미지 3개 중 2개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 4 단계, 이미지 3개 중 3개
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    댓글 쓰기
  5. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: 5 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: 5 단계, 이미지 2개 중 2개
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell.
    • Lift the PCB out.
    댓글 쓰기
  6. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 6 단계, 이미지 2개 중 1개 8BitDo Ultimate Wireless Button Conductive Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Lift button conductive pads out of the shell with your hands.
    • Replace or clean as needed.
    • If cleaning with water, make sure pads are fully dry before replacing.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
John Sweriduk
회원 가입일: 04/03/26
85 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 회원
UMASSD-BISWOKARMA-S26S1G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 46
전체 시간: 129
