주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AEE Mach 1 Camera Replacement
필요한 것
    1. AEE Mach 1 Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
      • Take out the AEE Mach 1 and place it on a surface with its propellers facing up.
      댓글 쓰기
    2. AEE Mach 1 Camera Replacement: 2 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Holding the base of a propeller with one hand, unscrew the propeller by hand in a clockwise direction. Complete this action on all 4 propellers.
      댓글 쓰기
    3. AEE Mach 1 Camera Replacement: 3 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the AEE Mach 1 upside down.
      • Remove the screws on the drone's arms using a Torx T5 screwdriver.
      댓글 쓰기
    4. AEE Mach 1 Camera Replacement: 4 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pry open the top panel of the drone using a spudger.
      • Do not completely remove the panel, as there will still be wired connections between the two halves.
      • Rotate the top panel slightly to reveal the four screws beneath each propellor arm.
      • Remove each of the four screws with a Phillips #0 screwdriver.
      • Lift off the top panel, as it should now be free from the rest of the device.
      댓글 쓰기
    5. AEE Mach 1 Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, remove the screws from the four corners of the inner white chassis.
      댓글 쓰기
    6. AEE Mach 1 Camera Replacement: 6 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Using a Spudger (or similar tool to scrap/pry with), remove the copper foil used as tape from the sides of the chassis.
      • Remove the small metal covering from the side boards.
      • This can be done by hand or with the assistance of a prying tool.
      댓글 쓰기
    7. AEE Mach 1 Camera Replacement: 7 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the four screws separating the side board from the white chassis.
      댓글 쓰기
    8. AEE Mach 1 Camera Replacement: 8 단계, 이미지 2개 중 1개 AEE Mach 1 Camera Replacement: 8 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the four screws from the large motherboard on the white chassis.
      • Lift the motherboard out of the case, revealing the camera cable.
      댓글 쓰기
    9. AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 1개 AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 2개 AEE Mach 1 Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Using the Phillips #00 screwdriver, remove the four screws holding the camera mechanism in place.
      • Lift the camera assembly out of the case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Cameron C Blanchard
회원 가입일: 09/16/20
524 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 37
전체 시간: 860
