주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AEE Mach 1 Drone Propeller Replacement
    1. AEE Mach 1 Drone Propeller Replacement, Propeller: 1 단계, 이미지 1개 중 1개
      • Make sure your drone is powered off and the battery is removed from the drone.
      • Identify the defective propeller on your drone.
      • Each propeller is marked as either 'A' or 'B'. Make sure the new propeller matches the old one.
      댓글 쓰기
    2. AEE Mach 1 Drone Propeller Replacement: 2 단계, 이미지 1개 중 1개
      • In the center of each propeller, near the base, there are two arrows.
      • The symbol circled in red indicates the direction to "unlock" the propeller from the drone; this symbol indicates the direction to unscrew the rotor off of its mount.
      • The symbol circled in orange indicates the direction to "lock" the propeller onto the drone; this symbol indicates the direction to screw the rotor back onto the mount.
      댓글 쓰기
    3. AEE Mach 1 Drone Propeller Replacement: 3 단계, 이미지 1개 중 1개
      • While keeping the motor under the propeller still, rotate the propeller in the direction shown to "unlock" the propeller.
      • The direction to unlock the propeller will depend on the letter labeled on the propeller.
      댓글 쓰기
    4. AEE Mach 1 Drone Propeller Replacement: 4 단계, 이미지 1개 중 1개
      • Once you unscrew the propeller from the drone you will then be able to inspect the area for any additional damages.
      댓글 쓰기
    5. AEE Mach 1 Drone Propeller Replacement: 5 단계, 이미지 1개 중 1개
      • Replace the defective propeller with one of the replacements that come with your drone, or you can attempt to fix the defective propeller.
      • To replace a propeller, simply place the rotor on the screw, and screw the propeller by rotating the propeller in the direction indicated by the arrow next to the “Lock” symbol.
      • The direction to lock the propeller on the drone will depend on the letter the propeller is labeled.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Patrick Lewis
회원 가입일: 09/04/19
394 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 36
전체 시간: 1,111
