주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APEX AP-GS918 Battery Replacement
필요한 것
    1. APEX AP-GS918 Battery Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 1개 APEX AP-GS918 Battery Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 2개 APEX AP-GS918 Battery Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 3개
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      댓글 쓰기
    2. APEX AP-GS918 Battery Replacement: 2 단계, 이미지 3개 중 1개 APEX AP-GS918 Battery Replacement: 2 단계, 이미지 3개 중 2개 APEX AP-GS918 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      댓글 쓰기
    3. APEX AP-GS918 Battery Replacement: 3 단계, 이미지 2개 중 1개 APEX AP-GS918 Battery Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      댓글 쓰기
    1. APEX AP-GS918 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 APEX AP-GS918 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • Begin removing the black tape covering the motherboard inside the tablet.
      댓글 쓰기
    2. APEX AP-GS918 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • You will need to desolder the two contact points that connect the battery to the mother board.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      댓글 쓰기
    3. APEX AP-GS918 Battery Replacement: 6 단계, 이미지 2개 중 1개 APEX AP-GS918 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
      • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Megan Lozicki
회원 가입일: 02/19/15
416 평판
안내서 4개를 작성함
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G1
3 회원들
안내서 19개를 작성함
1가이드 댓글
bien consejo, creo que es sencillo por todos para seguin estos pasos
harkhoscole - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 36
전체 시간: 975
