주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APEX AP-GS918 Camera Replacement
필요한 것
  1. APEX AP-GS918 Camera Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 1개 APEX AP-GS918 Camera Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 2개 APEX AP-GS918 Camera Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 3개
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    댓글 쓰기
  2. APEX AP-GS918 Camera Replacement: 2 단계, 이미지 3개 중 1개 APEX AP-GS918 Camera Replacement: 2 단계, 이미지 3개 중 2개 APEX AP-GS918 Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    댓글 쓰기
  3. APEX AP-GS918 Camera Replacement: 3 단계, 이미지 2개 중 1개 APEX AP-GS918 Camera Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    댓글 쓰기
  4. APEX AP-GS918 Camera Replacement, Camera: 4 단계, 이미지 3개 중 1개 APEX AP-GS918 Camera Replacement, Camera: 4 단계, 이미지 3개 중 2개 APEX AP-GS918 Camera Replacement, Camera: 4 단계, 이미지 3개 중 3개
    • Remove the black electrical tape covering the motherboard components along with the black cloth tape covering the camera itself.
    • Be careful when removing the black cloth tape from the camera on the top left corner of the tablet. The tape will likely stick and pull the camera with it.
    댓글 쓰기
  5. APEX AP-GS918 Camera Replacement: 5 단계, 이미지 3개 중 1개 APEX AP-GS918 Camera Replacement: 5 단계, 이미지 3개 중 2개 APEX AP-GS918 Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the white and gray connector that's holding the camera in place.
    • Use the black nylon spudger to eject the camera from its slot by gently lifting the gray clip vertically 90°.
    • Once ejected, you may easily remove the camera by pulling it from its slot.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Megan Lozicki
회원 가입일: 02/19/15
416 평판
안내서 4개를 작성함
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G1
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 37
전체 시간: 577
