주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APEX AP-GS918 Speakers Replacement
필요한 것
    1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 1개 APEX AP-GS918 Speakers Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 2개 APEX AP-GS918 Speakers Replacement, Power/Volume Button: 1 단계, 이미지 3개 중 3개
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      댓글 쓰기
    2. APEX AP-GS918 Speakers Replacement: 2 단계, 이미지 3개 중 1개 APEX AP-GS918 Speakers Replacement: 2 단계, 이미지 3개 중 2개 APEX AP-GS918 Speakers Replacement: 2 단계, 이미지 3개 중 3개
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      댓글 쓰기
    3. APEX AP-GS918 Speakers Replacement: 3 단계, 이미지 2개 중 1개 APEX AP-GS918 Speakers Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      댓글 쓰기
    1. APEX AP-GS918 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 1개 APEX AP-GS918 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 2개 APEX AP-GS918 Speakers Replacement, Speakers: 4 단계, 이미지 3개 중 3개
      • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
      • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
      • Start by peeling back the black electrical tape covering the motherboard components
      • You will also need to remove the black cloth tape covering the wire contact points.
      댓글 쓰기
    2. APEX AP-GS918 Speakers Replacement: 5 단계, 이미지 2개 중 1개 APEX AP-GS918 Speakers Replacement: 5 단계, 이미지 2개 중 2개
      • Now that the contacts are exposed, you can desolder them.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Megan Lozicki
회원 가입일: 02/19/15
416 평판
안내서 4개를 작성함
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G1
3 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 39
전체 시간: 562
