주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
APS Tech 101629 Internal Drive Component Replacement
필요한 것
    1. APS Tech 101629 Internal Drive Component Replacement, External Casing: 1 단계, 이미지 3개 중 1개 APS Tech 101629 Internal Drive Component Replacement, External Casing: 1 단계, 이미지 3개 중 2개 APS Tech 101629 Internal Drive Component Replacement, External Casing: 1 단계, 이미지 3개 중 3개
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      댓글 쓰기
    2. APS Tech 101629 Internal Drive Component Replacement: 2 단계, 이미지 2개 중 1개 APS Tech 101629 Internal Drive Component Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      댓글 쓰기
    3. APS Tech 101629 Internal Drive Component Replacement: 3 단계, 이미지 2개 중 1개 APS Tech 101629 Internal Drive Component Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      댓글 쓰기
    4. APS Tech 101629 Internal Drive Component Replacement: 4 단계, 이미지 1개 중 1개
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      댓글 쓰기
    5. APS Tech 101629 Internal Drive Component Replacement: 5 단계, 이미지 2개 중 1개 APS Tech 101629 Internal Drive Component Replacement: 5 단계, 이미지 2개 중 2개
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      댓글 쓰기
    1. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: 6 단계, 이미지 2개 중 1개 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: 6 단계, 이미지 2개 중 2개
      • Flip so device is upside down.
      • Remove 4 screws with Phillips #1 screw driver.
      • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
      댓글 쓰기
    2. APS Tech 101629 Internal Drive Component Replacement: 7 단계, 이미지 2개 중 1개 APS Tech 101629 Internal Drive Component Replacement: 7 단계, 이미지 2개 중 2개
      • Slide the internal drive component away from the back of the device.
      • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
      • Audio Connection
      • SCSI ID
      • Terminate On
      • SCSI Connection
      • DC Input (power)
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alexis Weckel
회원 가입일: 04/11/11
140 평판
안내서 3개를 작성함
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G60
5 회원들
안내서 48개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 26
전체 시간: 1,537
