주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Chromebook C300MA-DH01 Battery Replacement
필요한 것
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the Chromebook over so the bottom of the device is facing up.
    댓글 쓰기
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: 2 단계, 이미지 2개 중 1개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
    댓글 쓰기
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: 3 단계, 이미지 3개 중 1개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 3 단계, 이미지 3개 중 2개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 3 단계, 이미지 3개 중 3개
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
    댓글 쓰기
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: 4 단계, 이미지 3개 중 1개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 4 단계, 이미지 3개 중 2개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 4 단계, 이미지 3개 중 3개
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
    댓글 쓰기
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: 5 단계, 이미지 2개 중 1개 ASUS Chromebook C300MA-DH01 Battery  Replacement: 5 단계, 이미지 2개 중 2개
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
    댓글 쓰기
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
amer khalil
회원 가입일: 09/26/17
101 평판
안내서 1개를 작성함
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 447
