주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS D550MA-DS01 Keyboard Module Replacement
필요한 것
    1. ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 1 단계, 이미지 2개 중 1개 ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 1 단계, 이미지 2개 중 2개
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
      댓글 쓰기
    2. ASUS D550MA-DS01 Keyboard Module Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the laptop over and open the display.
      • Insert the flat edge of the spudger into the crease of the keyboard cover.
      • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
      • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
      댓글 쓰기
    3. ASUS D550MA-DS01 Keyboard Module Replacement: 3 단계, 이미지 2개 중 1개 ASUS D550MA-DS01 Keyboard Module Replacement: 3 단계, 이미지 2개 중 2개
      • Make sure that the entire cover has been released from the plastic clips.
      • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
      • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
      댓글 쓰기
    4. ASUS D550MA-DS01 Keyboard Module Replacement: 4 단계, 이미지 1개 중 1개
      • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
      • Disconnect the three data cables from the motherboard.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      댓글 쓰기
    5. ASUS D550MA-DS01 Keyboard Module Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the fully disconnected keyboard module from the laptop.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
redacted
회원 가입일: 09/15/15
566 평판
안내서 3개를 작성함
3가이드 댓글
Does anybody knows how to remove the keyboard from the keyboard module??I want to replace the keyboard not the whole piece
mfq1979 - 답글 공유
where can I get a keyboard replacement
Kwame Mitchell - 답글 공유
http://www.newegg.com
Replacement Keyboard N2840 s/n EBNOCX62041047D sold by, Alpha Vr Electronics, 860-755-2309 ext. 22831 $20.99
Eugene Bohrmann - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 46
전체 시간: 2,845
