주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS EEE PC701SD-WHI004X Keyboard Replacement
필요한 것
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Flip the laptop over, you should see two battery tabs.
      • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
      댓글 쓰기
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: 2 단계, 이미지 2개 중 1개 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • While holding the left tab towards the left. Gently slide the battery out of the laptop.
      댓글 쓰기
    1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
      • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
      • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
      • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
      댓글 쓰기
    2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: 4 단계, 이미지 3개 중 1개 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 4 단계, 이미지 3개 중 2개 ASUS EEE PC701SD-WHI004X Keyboard Replacement: 4 단계, 이미지 3개 중 3개
      • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
      • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
      • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
mir
회원 가입일: 03/24/17
409 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G8
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 941
