주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Eee PC 1018P Hard Drive Replacement
필요한 것
    1. ASUS Eee PC 1018P Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
      댓글 쓰기
    2. ASUS Eee PC 1018P Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
      댓글 쓰기
    3. ASUS Eee PC 1018P Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 ASUS Eee PC 1018P Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
      • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
      • Pull the battery pack up and away from you to completely free it from its recess in the case.
      댓글 쓰기
    1. ASUS Eee PC 1018P Hard Drive Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the screws securing the bottom case to the keyboard.
      • Remove the six 3.68 mm screws and the single 4.45 mm screw that had been concealed by the battery.
      • Use a pair of tweezers to remove the two rubber covers located at the upper left and right corners.
      • With the rubber covers gone, two 4.52 mm screws should now be visible. Remove these screws.
      댓글 쓰기
    2. ASUS Eee PC 1018P Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Pry the cover free from the chasis by inserting the plastic opening tool between the keyboard and the lower body of the Asus Eee PC 1018P.
      • Prying a keyboard from a laptop requires a lot of force, but the keyboard also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
      댓글 쓰기
    3. ASUS Eee PC 1018P Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the outside edge of the keyboard upward and inward towards the screen. (See warning below.)
      • Take care not to lift the keyboard too high from the motherboard, as this may sever the ribbon cables that are still attached.
      댓글 쓰기
    4. ASUS Eee PC 1018P Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 ASUS Eee PC 1018P Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the black ribbon cable from the motherboard.
      • Use the tip of the plastic opening tool to push the black tabs on both sides of the white connector forward toward the display.
      • Pushing forward on one side will push the other side back toward the touch pad. Repeat the previous step until both black tabs will not move any farther.
      • Carefully pull the black ribbon cable horizontally toward the display until it slides free from the white motherboard connector. If it does not move when pulling on it, repeat previous steps until it does.
      댓글 쓰기
    5. ASUS Eee PC 1018P Hard Drive Replacement: 8 단계, 이미지 3개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 8 단계, 이미지 3개 중 2개 ASUS Eee PC 1018P Hard Drive Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the white ribbon cable from the motherboard.
      • Insert the plastic opening tool under the small lip of the white ribbon connector, and pry upwards to pop the motherboard connector up.
      • Carefully remove the white ribbon cable by pulling it horizontally towards the touch pad.
      댓글 쓰기
    6. ASUS Eee PC 1018P Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
      • The keyboard is now fully disconnected and can now be removed from the main body of the Asus Eee PC 1018P.
      댓글 쓰기
    1. ASUS Eee PC 1018P Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
      • Use a Phillips #0 screwdriver to remove the two 4.52 mm screws securing the hard drive case to the laptop.
      댓글 쓰기
    2. ASUS Eee PC 1018P Hard Drive Replacement: 11 단계, 이미지 1개 중 1개
      • Carefully peel off the tape that secures the black cables to the hard drive.
      • Do not discard the tape.
      댓글 쓰기
    3. ASUS Eee PC 1018P Hard Drive Replacement: 12 단계, 이미지 3개 중 1개 ASUS Eee PC 1018P Hard Drive Replacement: 12 단계, 이미지 3개 중 2개 ASUS Eee PC 1018P Hard Drive Replacement: 12 단계, 이미지 3개 중 3개
      • Lift the left side of the hard drive slightly. Gently pull the hard drive to the left in order to free it from the pin connection on the right side.
      • Continue pulling the hard drive out from the socket until it's free from the rest of the laptop.
      • Removing the hard drive at too great or too small an angle can cause damage to both the hard drive and the connector to the motherboard.
      댓글 쓰기
    4. ASUS Eee PC 1018P Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
      • Use a Phillips #0 screwdriver to remove the four 3.68 mm screws securing the hard drive case to the hard drive. There are two on each side of the hard drive case.
      댓글 쓰기
    5. ASUS Eee PC 1018P Hard Drive Replacement: 14 단계, 이미지 1개 중 1개
      • The hard drive is now fully removed and ready to be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Daniel Rodman
회원 가입일: 01/20/12
309 평판
안내서 2개를 작성함
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 회원
CPSU-MANESS-W12S8G13
4 회원들
안내서 21개를 작성함
3가이드 댓글
It helps when you start to pry open the cover at the SD card slot instead of some random point as there is some space to go between. Don't insert your tool too deeply though or you you might damage the frame that sits further in.
Andre - 답글 공유
Short, clear, accurate. Thank you! awesome student :)
Alex - 답글 공유
Any advice on replacing with a SSD drive?
SATA II 3GBs
Would a 6gbs drive be a waste? or even work?
same question for SATA III
terrymcp63 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 42
전체 시간: 9,714
