주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Eee PC 1018P RAM Replacement
필요한 것
    1. ASUS Eee PC 1018P RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
      댓글 쓰기
    2. ASUS Eee PC 1018P RAM Replacement: 2 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P RAM Replacement: 2 단계, 이미지 2개 중 2개
      • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
      댓글 쓰기
    3. ASUS Eee PC 1018P RAM Replacement: 3 단계, 이미지 3개 중 1개 ASUS Eee PC 1018P RAM Replacement: 3 단계, 이미지 3개 중 2개 ASUS Eee PC 1018P RAM Replacement: 3 단계, 이미지 3개 중 3개
      • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
      • Pull the battery pack up and away from you to completely free it from its recess in the case.
      댓글 쓰기
    1. ASUS Eee PC 1018P RAM Replacement, RAM: 4 단계, 이미지 1개 중 1개
      • With the battery removed, locate the RAM cover.
      댓글 쓰기
    2. ASUS Eee PC 1018P RAM Replacement: 5 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P RAM Replacement: 5 단계, 이미지 2개 중 2개
      • Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free.
      • With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
      댓글 쓰기
    3. ASUS Eee PC 1018P RAM Replacement: 6 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P RAM Replacement: 6 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module.
      • In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
      • The RAM module will pop upward at a slight angle when both tabs are detached.
      댓글 쓰기
    4. ASUS Eee PC 1018P RAM Replacement: 7 단계, 이미지 2개 중 1개 ASUS Eee PC 1018P RAM Replacement: 7 단계, 이미지 2개 중 2개
      • Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil.
      • Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
      댓글 쓰기
    5. ASUS Eee PC 1018P RAM Replacement: 8 단계, 이미지 1개 중 1개
      • Remove RAM module entirely for repair or replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Patrick Hallahan
회원 가입일: 01/29/12
38 평판
안내서 1개를 작성함
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 회원
CPSU-MANESS-W12S8G13
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 21
전체 시간: 3,822
