주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS GL752VW-DH74 Keyboard Replacement
필요한 것
    1. ASUS GL752VW-DH74 Keyboard  Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
      • Begin by putting the needle into the hole in the disk tray.
      댓글 쓰기
    2. ASUS GL752VW-DH74 Keyboard  Replacement: 2 단계, 이미지 1개 중 1개
      • Use the spudger to help ease out the disk drive.
      댓글 쓰기
    3. ASUS GL752VW-DH74 Keyboard  Replacement: 3 단계, 이미지 1개 중 1개
      • Pull out disk tray entirely.
      댓글 쓰기
    1. ASUS GL752VW-DH74 Keyboard  Replacement, SSD: 4 단계, 이미지 1개 중 1개
      • Unscrew both 8mm phillip's head screws that hold on the access gate.
      댓글 쓰기
    2. ASUS GL752VW-DH74 Keyboard  Replacement: 5 단계, 이미지 1개 중 1개
      • Use either the your finger, the screw driver, or a spudger to pop out the gate.
      댓글 쓰기
    3. ASUS GL752VW-DH74 Keyboard  Replacement: 6 단계, 이미지 1개 중 1개
      • From here, you can access the hardrive, motherboard, SSD, and RAM.
      댓글 쓰기
    4. ASUS GL752VW-DH74 Keyboard  Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the 4mm screw holding in the SSD.
      • Note that the screw is holding it down so it will pop up once the screw is removed.
      댓글 쓰기
    5. ASUS GL752VW-DH74 Keyboard  Replacement: 8 단계, 이미지 1개 중 1개
      • Remove SSD from slot.
      댓글 쓰기
    1. ASUS GL752VW-DH74 Keyboard  Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
      • Start by unplugging the laptop and turning it upside down. There are 3 screws in the disk drive, remove those using a Phillips #0 screwdriver.
      댓글 쓰기
    2. ASUS GL752VW-DH74 Keyboard  Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the medium sized panel attached on the back. Then using your Phillips #0 screwdriver, remove all 8 screws.
      댓글 쓰기
    3. ASUS GL752VW-DH74 Keyboard  Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the entire large back panel (outer shell) by removing the screws closer to the outer edge.
      댓글 쓰기
    4. ASUS GL752VW-DH74 Keyboard  Replacement: 12 단계, 이미지 3개 중 1개 ASUS GL752VW-DH74 Keyboard  Replacement: 12 단계, 이미지 3개 중 2개 ASUS GL752VW-DH74 Keyboard  Replacement: 12 단계, 이미지 3개 중 3개
      • Use the blue opening tool to gently separate the back panel by loosening it on all sides to ease the outer shell of the laptop until it separates.
      댓글 쓰기
    5. ASUS GL752VW-DH74 Keyboard  Replacement: 13 단계, 이미지 1개 중 1개
      • Gently lift the outer shell up until the white, gold and silver power strips are visible. Proceed by removing the strips from the bottom side of the keyboard. Finish removing the outer shell.
      댓글 쓰기
    6. ASUS GL752VW-DH74 Keyboard  Replacement: 14 단계, 이미지 1개 중 1개
      • Remove the two Phillips #0 screws located on the panel above the white power strip.
      댓글 쓰기
    7. ASUS GL752VW-DH74 Keyboard  Replacement: 15 단계, 이미지 1개 중 1개
      • Gently take off the metal keyboard cover by using the blue opening tool.
      댓글 쓰기
    8. ASUS GL752VW-DH74 Keyboard  Replacement: 16 단계, 이미지 2개 중 1개 ASUS GL752VW-DH74 Keyboard  Replacement: 16 단계, 이미지 2개 중 2개
      • Lift up the keyboard panel and replace it with the new one.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ryan Maitland
회원 가입일: 10/22/17
224 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 회원
UMASSD-ISAACSON-F17S1G3
3 회원들
안내서 60개를 작성함
3가이드 댓글
This is an extremely useful tutorial for those who have patience and curious to learn. Excellent job by the authors. Thank you.
Mohan Krishnan - 답글 공유
This guide needs more work. The metal keyboard has small black pins that keep it in place. They will need to be melted by a heating/soldering gun, and then remelted to keep the new keyboard in place.
gummielindsays - 답글 공유
This guide is incomplete. You will require a soldering pencil to reattach the new keyboard to its metal backing plate and the laptop faceplate. It could also be useful in releasing the old keyboard from the backing plate and faceplate. if you are slow and cautious it will probably take you 90 to 120 minutes to complete. 40 minutes is only if you have done this type of keyboard before.
Also read the comments regarding the access bay screws that need to be removed during disassembly and remember to remove the sata drive as well.
Kari Hartman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 52
전체 시간: 7,219
