주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS MeMo Pad FHD10 Battery Replacement
필요한 것
    1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      댓글 쓰기
    2. ASUS MeMo Pad FHD10 Battery Replacement: 2 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      댓글 쓰기
    3. ASUS MeMo Pad FHD10 Battery Replacement: 3 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      댓글 쓰기
    4. ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Dmitry
회원 가입일: 01/21/15
391 평판
안내서 3개를 작성함
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G5
4 회원들
안내서 10개를 작성함
1가이드 댓글
Where i can get new battery for this tablet?
Night Knight - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 45
전체 시간: 10,796
