주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS MeMo Pad FHD10 Camera Replacement
필요한 것
    1. ASUS MeMo Pad FHD10 Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Make sure that the device is turned off as a precaution.
      • Unplug the charger and remove any memory card you may have in the device.
      • Wedge the plastic opening tool between the front and back cover on every side.
      • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
      • Once disconnected, remove the back cover from the device screen.
      댓글 쓰기
    2. ASUS MeMo Pad FHD10 Camera Replacement: 2 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the protective copper sticker and all tape fixed on the device.
      • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
      • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
      댓글 쓰기
    3. ASUS MeMo Pad FHD10 Camera Replacement: 3 단계, 이미지 2개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
      댓글 쓰기
    4. ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
      • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
      • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
      댓글 쓰기
    1. ASUS MeMo Pad FHD10 Camera Replacement, Speakers: 5 단계, 이미지 1개 중 1개
      • Remove three screws using a Phillips #00 screwdriver.
      댓글 쓰기
    2. ASUS MeMo Pad FHD10 Camera Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
      • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
      댓글 쓰기
    3. ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 7 단계, 이미지 3개 중 3개
      • Gently use your hands to remove the speakers.
      댓글 쓰기
    1. ASUS MeMo Pad FHD10 Camera Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
      • Remove the five screws using a Phillips #00 screwdriver.
      댓글 쓰기
    2. ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement: 9 단계, 이미지 3개 중 3개
      • Carefully disconnect the cord that connects the on/off button to the motherboard
      • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
      댓글 쓰기
    3. ASUS MeMo Pad FHD10 Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Use your hands to remove the motherboard from the device.
      댓글 쓰기
    1. ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 1개 ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 2개 ASUS MeMo Pad FHD10 Camera Replacement, Front and Rear cameras: 11 단계, 이미지 3개 중 3개
      • Identify the location of front and rear cameras on the motherboard.
      • The front and rear cameras can be removed by pulling them out gently using hands.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Dmitry
회원 가입일: 01/21/15
391 평판
안내서 3개를 작성함
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G5
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 34
전체 시간: 926
