주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS PadFone X Front Facing Camera Replacement
필요한 것
    1. ASUS PadFone X Front Facing Camera  Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
      • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose.
      댓글 쓰기
    2. ASUS PadFone X Front Facing Camera  Replacement: 2 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
      댓글 쓰기
    3. ASUS PadFone X Front Facing Camera  Replacement: 3 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 3 단계, 이미지 2개 중 2개
      • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
      • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
      댓글 쓰기
    4. ASUS PadFone X Front Facing Camera  Replacement: 4 단계, 이미지 1개 중 1개
      • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
      • Applying too much force will damage the connector.
      댓글 쓰기
    5. ASUS PadFone X Front Facing Camera  Replacement: 5 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 5 단계, 이미지 2개 중 2개
      • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
      • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
      댓글 쓰기
    6. ASUS PadFone X Front Facing Camera  Replacement: 6 단계, 이미지 1개 중 1개
      • Using a spudger, pry the vibration motor connector from the motherboard.
      댓글 쓰기
    7. ASUS PadFone X Front Facing Camera  Replacement: 7 단계, 이미지 1개 중 1개
      • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
      • Applying too much force will damage the conector
      댓글 쓰기
    8. ASUS PadFone X Front Facing Camera  Replacement: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using the tweezers, remove the rear camera from the Padfone X.
      • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
      댓글 쓰기
    9. ASUS PadFone X Front Facing Camera  Replacement: 9 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 9 단계, 이미지 2개 중 2개
      • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
      • Do this for all the clips holding the panel down.
      • After all clips are bent away, remove the panel.
      댓글 쓰기
    10. ASUS PadFone X Front Facing Camera  Replacement: 10 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 10 단계, 이미지 2개 중 2개
      • Disconnect the first connector by prying it upward using the blue plastic opening tool.
      • Disconnect the second connector by first lifting the lock then pulling the connector outward.
      댓글 쓰기
    11. ASUS PadFone X Front Facing Camera  Replacement: 11 단계, 이미지 3개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 11 단계, 이미지 3개 중 2개 ASUS PadFone X Front Facing Camera  Replacement: 11 단계, 이미지 3개 중 3개
      • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
      • Work your way around until the motherboard is free.
      댓글 쓰기
    12. ASUS PadFone X Front Facing Camera  Replacement: 12 단계, 이미지 1개 중 1개
      • Flip the motherboard over and locate the front facing camera.
      • Using the tweezers gently remove the black locking mechanism.
      • The black locking mechanism is very fragile and extreme care should be exercised during removal.
      댓글 쓰기
    13. ASUS PadFone X Front Facing Camera  Replacement: 13 단계, 이미지 2개 중 1개 ASUS PadFone X Front Facing Camera  Replacement: 13 단계, 이미지 2개 중 2개
      • Use the tweezers to gently pull on the connector to remove the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Keith Cooper
회원 가입일: 01/24/17
122 평판
안내서 1개를 작성함
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G1
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 36
전체 시간: 640
