주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Q405U RAM Replacement
필요한 것
  1. ASUS Q405U RAM Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    댓글 쓰기
  2. ASUS Q405U RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    댓글 쓰기
  3. ASUS Q405U RAM Replacement: 3 단계, 이미지 3개 중 1개 ASUS Q405U RAM Replacement: 3 단계, 이미지 3개 중 2개 ASUS Q405U RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    댓글 쓰기
  4. ASUS Q405U RAM Replacement: 4 단계, 이미지 2개 중 1개 ASUS Q405U RAM Replacement: 4 단계, 이미지 2개 중 2개
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    댓글 쓰기
  5. ASUS Q405U RAM Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Pull the metal arms out a couple of millimeters to release the RAM stick.
    • It will pop up at a 45 degree angle.
    • Slide the RAM stick from the socket on the motherboard.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jeremiah Baselice
회원 가입일: 10/25/21
569 평판
안내서 5개를 작성함
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G8
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 34
전체 시간: 1,726
