주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ROG Spatha X Scroll Wheel Replacement
필요한 것
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: 1 단계, 이미지 3개 중 1개 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: 1 단계, 이미지 3개 중 2개 ASUS ROG Spatha X Scroll Wheel Replacement, Mouse Cover: 1 단계, 이미지 3개 중 3개
      • Make sure the mouse is unplugged and the power switch on the underside is set to the off position.
      • Use the pointed edge of a spudger to remove the four soft rubber covers on the underside of the mouse.
      • Use the included Torx screwdriver, or a T3 Torx screwdriver, to remove the four 4 mm screws.
      댓글 쓰기
    2. ASUS ROG Spatha X Scroll Wheel Replacement: 2 단계, 이미지 2개 중 1개 ASUS ROG Spatha X Scroll Wheel Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the upper mouse cover up and off.
      댓글 쓰기
    1. ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: 3 단계, 이미지 3개 중 1개 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: 3 단계, 이미지 3개 중 2개 ASUS ROG Spatha X Scroll Wheel Replacement, Scroll Wheel: 3 단계, 이미지 3개 중 3개
      • Remove the Phillips screw securing the ribbon cable scroll wheel.
      • Disconnect the ribbon cable from the scroll wheel.
      댓글 쓰기
    2. ASUS ROG Spatha X Scroll Wheel Replacement: 4 단계, 이미지 3개 중 1개 ASUS ROG Spatha X Scroll Wheel Replacement: 4 단계, 이미지 3개 중 2개 ASUS ROG Spatha X Scroll Wheel Replacement: 4 단계, 이미지 3개 중 3개
      • There is a plastic axle holding the scroll wheel in place. It is cinched into a plastic housing unit towards the right side of the mouse (towards the pinky rest).
      • Use one hand to gently pull the housing for the axle away from the scroll wheel as you simultaneously use the other hand to pull up and away from the housing unit.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
cgrabowski1
회원 가입일: 03/21/25
678 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-4, Botvin Spring 2025 UMass Dartmouth, Team 3-4, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G4
3 회원들
안내서 5개를 작성함
1가이드 댓글
Easy replacement but good luck finding the part. It's not sold ANYWHERE.
Tyler Pratt - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 27
지난 30일: 122
전체 시간: 1,178
