주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS UX50V-RX05 Optical Drive Replacement
필요한 것
  1. ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 ASUS UX50V-RX05 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
    댓글 쓰기
  2. ASUS UX50V-RX05 Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
    댓글 쓰기
  3. ASUS UX50V-RX05 Optical Drive Replacement: 3 단계, 이미지 2개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
    댓글 쓰기
  4. ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: 4 단계, 이미지 3개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: 4 단계, 이미지 3개 중 2개 ASUS UX50V-RX05 Optical Drive Replacement, Case Removal: 4 단계, 이미지 3개 중 3개
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
    댓글 쓰기
  5. ASUS UX50V-RX05 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
    댓글 쓰기
  6. ASUS UX50V-RX05 Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 ASUS UX50V-RX05 Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
    댓글 쓰기
  7. ASUS UX50V-RX05 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully lift and remove the plastic cover to avoid damaging anything.
    댓글 쓰기
  8. ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: 8 단계, 이미지 2개 중 1개 ASUS UX50V-RX05 Optical Drive Replacement, Optical Drive: 8 단계, 이미지 2개 중 2개
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
James
회원 가입일: 02/14/17
663 평판
안내서 6개를 작성함
USF Tampa, Team 20-2, Remmell Spring 2017 USF Tampa, Team 20-2, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 466
