주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS VG248 Disassembly
필요한 것
  1. ASUS VG248 Disassembly, ASUS VG248 Disassembly: 1 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly, ASUS VG248 Disassembly: 1 단계, 이미지 2개 중 2개
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
    댓글 쓰기
  2. ASUS VG248 Disassembly: 2 단계, 이미지 1개 중 1개
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    댓글 쓰기
  3. ASUS VG248 Disassembly: 3 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 3 단계, 이미지 2개 중 2개
    • Remove the stand from the display.
    댓글 쓰기
  4. ASUS VG248 Disassembly: 4 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 4 단계, 이미지 2개 중 2개
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
    댓글 쓰기
  5. ASUS VG248 Disassembly: 5 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 5 단계, 이미지 2개 중 2개
    • Repeat the procedure around the display, lifting up the center of the next side.
    댓글 쓰기
  6. ASUS VG248 Disassembly: 6 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 6 단계, 이미지 2개 중 2개
    • Move around to the other long side and lift up on the center of the bezel.
    댓글 쓰기
  7. ASUS VG248 Disassembly: 7 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 7 단계, 이미지 2개 중 2개
    • Grip the center of the final side and lift the bezel away from the rear case.
    댓글 쓰기
  8. ASUS VG248 Disassembly: 8 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 8 단계, 이미지 2개 중 2개
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    댓글 쓰기
  9. ASUS VG248 Disassembly: 9 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
    댓글 쓰기
  10. ASUS VG248 Disassembly: 10 단계, 이미지 3개 중 1개 ASUS VG248 Disassembly: 10 단계, 이미지 3개 중 2개 ASUS VG248 Disassembly: 10 단계, 이미지 3개 중 3개
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    댓글 쓰기
  11. ASUS VG248 Disassembly: 11 단계, 이미지 1개 중 1개
    • Remove the bezel.
    댓글 쓰기
  12. ASUS VG248 Disassembly: 12 단계, 이미지 2개 중 1개 ASUS VG248 Disassembly: 12 단계, 이미지 2개 중 2개
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    댓글 쓰기
  13. ASUS VG248 Disassembly: 13 단계, 이미지 1개 중 1개
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 23명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,618 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,617개를 작성함
11가이드 댓글
Do you know of any place that sell the replacement lcd screen?
treymcbrd - 답글 공유
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - 답글 공유
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg - 답글 공유
Hi. A really small bug got stuck within my screen and I accidentally squished it so now it’s dead in there and I want to clean it. How would I remove the top layer of the screen? Because from what I can see it seems like it got squished between the glass and the actual LCD screen itself.
Carl Viernes - 답글 공유
Me too, same issue, a very small bug I thaught was outside, acutally was inside and I squeezed it. It's very small but the dot is disturbing.
Is it possibile to take a part the layers of the LCD screen?
I have an ASUS PA248
Thank you
Piero - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 155
지난 30일: 716
전체 시간: 136,996
