주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS X44H-BBR4 Keyboard Replacement
필요한 것
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Open the laptop to show the keyboard.
    댓글 쓰기
  2. ASUS X44H-BBR4 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
    댓글 쓰기
  3. ASUS X44H-BBR4 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 ASUS X44H-BBR4 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 ASUS X44H-BBR4 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
    댓글 쓰기
  4. ASUS X44H-BBR4 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 ASUS X44H-BBR4 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
    댓글 쓰기
  5. ASUS X44H-BBR4 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 ASUS X44H-BBR4 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the keyboard over to reveal the back of it and what is underneath.
    댓글 쓰기
  6. ASUS X44H-BBR4 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 ASUS X44H-BBR4 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 ASUS X44H-BBR4 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
    댓글 쓰기
  7. ASUS X44H-BBR4 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the keyboard completely.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kelly Merlo
회원 가입일: 10/14/15
500 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-3, Catania Fall 2015 UMass Dartmouth, Team 4-3, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G3
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 1,489
