주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS X550LB-DS71 Motherboard Replacement
필요한 것
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
    댓글 쓰기
  2. ASUS X550LB-DS71 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
    댓글 쓰기
  3. ASUS X550LB-DS71 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 ASUS X550LB-DS71 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
    댓글 쓰기
  4. ASUS X550LB-DS71 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
    댓글 쓰기
  5. ASUS X550LB-DS71 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
    댓글 쓰기
  6. ASUS X550LB-DS71 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
    댓글 쓰기
  7. ASUS X550LB-DS71 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
    댓글 쓰기
  8. ASUS X550LB-DS71 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 ASUS X550LB-DS71 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
    댓글 쓰기
  9. ASUS X550LB-DS71 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 ASUS X550LB-DS71 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 ASUS X550LB-DS71 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Dyer
회원 가입일: 09/25/17
550 평판
안내서 5개를 작성함
USF Tampa, Team S16-G1, Eyestone Fall 2017 USF Tampa, Team S16-G1, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 47
전체 시간: 2,670
